Выберете то, что вам нужно
Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
Replace the spring.
The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
5 участников успешно повторили данное руководство.
4 Комментариев
Where can I buy a replacement spring?
you can get a replacement or an upgrade spring at the website www.nfstrike.com
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
