Введение
My modified Nerf Longshot (nicknamed: Leviathan) is a significant powerhouse compared to most stock foam dart blasters. Although I have yet to measure the muzzle velocity of the Leviathan, I can visually notice double the muzzle velocity compared to stock nerf blasters, at least 140 feet per second (FPS) versus 70 FPS. The reason for a high FPS comes down to a powerful spring pushing a plunger forward in an airtight tube to force air into the firing chamber where the dart lies, propelling the dart through an airtight inner barrel for a high muzzle velocity. However, the plunger needs an O-ring as an air seal, and worn-out O-rings will slip off the plunger, disabling the blaster. I will show you how to replace the O-ring in this guide.
Выберете то, что вам нужно
You can tell the blaster is not primed when the spring pushes the front pump handle or side handle.
If the blaster is primed, you can release the spring tension by pulling the trigger.
Remove the outer barrel attachment and optic.
If your optic is attached via a Picatinny rail, also remove the rail by reversing the installation steps.
Remove the screws from the pump-action handle using a Phillips #00 screwdriver.
Remove the six screws from the stock using a Phillips #00 screwdriver.
Remove all screws holding the blaster shell together using a Phillips #00 screwdriver.
Two screws are longer than the rest.
Two screws are shorter than the rest.
Lift the top half and set it aside to reveal the internals.
Remove the screws from the arch holding the plunger arm and plunger tube in place.
Remove the plunger tube.
The orange nerf rail tooth and corresponding spring may fly out during the fix. If so, neatly set them aside, but make sure to reinstall during reassembly.
Remove the screws connecting the plunger tube end cap to the plunger tube using a Phillips #00 screwdriver.
Pull out the plunger to reveal the worn-out O-ring on the plunger head.
With all maintenance completed, the Leviathan is back on the hunt. Good hunting, Nerf snipers.
