Введение
In some cases when you pull the cocking mechanism back it may not lock. When this happens first check to make sure that you have pulled the mechanism back far enough to lock. After you have checked and it is still not locking open up the crossbow making sure to follow the steps in this guide.
  1. There are 19 1.0 cm screws.
    • There are 19 1.0 cm screws.
  2. The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Купить сейчас
    iPhone X Fix Kits
    Купить сейчас
  4. Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  5. Separate each part of the Nerf crossbow.
    • Separate each part of the Nerf crossbow.
  6. Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  7. The cocking device needs to be attached to the plunger in order to function properly.
    • The cocking device needs to be attached to the plunger in order to function properly.
Заключение
Benjamin Bucklin
Участник с: 09.10.2014
1 Репутация
Автор 3 руководств
Команда
University of Maine, Team 1-12, Diaz Fall 2014 Member of University of Maine, Team 1-12, Diaz Fall 2014
UMAINE-DIAZ-F14S1G12
3 членов
Автор 3 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 19
За всё время: 2,420
