Введение
There are some instances when the spring which allows a person to fire a Nerf crossbow breaks. One you have opened up the Nerf crossbow you will be able to tell whether or not the spring has broken. If in fact you are dealing with a broken swing then you are in luck since it can be replaced.
Выберете то, что вам нужно
Now that the spring has been reattached to the trigger repeat step two.
Finish by performing steps two and three in reverse order.
Еще один человек закончил это руководство.
Один комментарий
how do you get the arms/wings off without damaging the lock on clip?
