Выберете то, что вам нужно
Wedge a spudger between the black front panel and the white outer shell.
Slide the spudger around the edge of the panel to pop it off.
Disconnect the microphone cable to separate the motherboard from the main camera unit.
Wedge a nylon spudger between the white outer shell and the battery.
Slowly pull the battery away from the plastic camera cover.
Еще один человек закончил это руководство.
3 Комментариев
Do you have the P/N of the battery??
Where to buy a replacement battery?
I believe the battery model is GS24 (3.65V, 600 mAh/21.9Wh).
I also saw this on the battery
GPN: G823-00181-01
