Введение
The motherboard functions as the central hub of communication between all of the components in a device. If your device isn’t functioning properly and if multiple components are failing, the motherboard may need to be replaced. Use this guide to replace the motherboard in the Nest Hello.
Выберете то, что вам нужно
Insert the pick between the black faceplate and white casing of the Nest Hello.
Pry the faceplate away from the device with the opening pick.
Completely remove the faceplate from the device, do not be afraid to pull hard.
Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
Insert opening pick between the white casing and the black internal circuitry and pry it out.
Use the Phillips #000 to remove the two screws holding the ribbon cable to the white casing.
Remove the six smaller screws shown with the Phillips #000 screwdriver.
Remove the three larger screws shown with the Phillips #000 screwdriver.
Holding the device as shown push the circuit board away from you and up to free it from the clips.
Use the Phillips #000 screwdriver to remove the three screws holding the last circuit board to the black plastic housing.
Insert the pick underneath the black connectors and pry them upward to disconnect them from the circuit board.
Work your way around the device, prying the circuit board away from the housing.
2 Комментариев
@viteapen13 Hi Daniel, question for you. On step 9, is the enclosing shell for the main board (top portion of the photo) metallic or plastic? Also, the blue material off the shell foam? Last, the blue regular stuff from the bottom board, is that some kind of thermal paste? Thanks.
