Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement
Выберете то, что вам нужно
  1. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Case: шаг 1, изображение 1 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Case: шаг 1, изображение 2 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Case: шаг 1, изображение 3 из 3
    • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
    • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
  2. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 2, изображение 1 из 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
    • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
  3. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 3, изображение 1 из 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 3, изображение 2 из 2
    • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
    • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
    • Gently pull the side of the case off as it comes loose.
  4. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 4, изображение 1 из 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 4, изображение 2 из 2
    • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
    • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
  5. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 5, изображение 1 из 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 5, изображение 2 из 2
    • Using the plastic opening tool, gently pry the right panel from the device.
    • Replace either side of the plastic case as needed.
  6. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Camera/Lens: шаг 6, изображение 1 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Camera/Lens: шаг 6, изображение 2 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Camera/Lens: шаг 6, изображение 3 из 3
    • Unscrew the four 4.0 mm Phillips #00 screws on either side of the transparent case.
    • Separate the transparent half of the case from the white half.
    • Only separate the two halves enough for them to be apart. The flat ribbon cable is short and its connection is delicate.
  7. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 7, изображение 1 из 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 7, изображение 2 из 2
    • Lift the small thin black rectangular latch that covers the connectors of the flat ribbon cable.
    • The latch is very flat, so use a finger nail or a spudger to lift it. Do not use any sharp edge like a knife as it will likely damage the device!
    • With the latch lifted, the cable will pull away freely as you separate the white half from the transparent half.
  8. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 8, изображение 1 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 8, изображение 2 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 8, изображение 3 из 3
    • Repeat the same process as in Step 6 to release the flat ribbon cable from the black rectangular latch
    • Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on.
    • Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
    • Be sure that the transparent case or the black motherboard are being held or resting on a surface so that neither falls when the clip is released.
  9. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 9, изображение 1 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 9, изображение 2 из 3 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 9, изображение 3 из 3
    • Remove the black plastic that contains the camera from its place.
    • Discard and replace this part as needed.
  10. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement, Infrared LED and Motion Sensor Motherboard: шаг 10, изображение 1 из 1
    • Remove the three 3mm Phillips #000 screws.
  11. Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 11, изображение 1 из 2 Netgear Arlo 2 Camera HD Security System Infrared LED and Motion Sensor Motherboard Replacement: шаг 11, изображение 2 из 2
    • Pull the infrared LED and motion sensor mother board out of the device.
    • Replace this as needed.
Заключение
Katherine McCombs
Участник с: 10/25/18
469 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team S2-G4, Peak Fall 2018 Участник UMass Dartmouth, Team S2-G4, Peak Fall 2018
UMASSD-PEAK-F18S2G4
3 членов
Автор 10 руководств
Один комментарий
Do you know the pinout to the ir led
Atrain ley - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,289
