Введение
This guide will take you through the process involved with removing a capacitor. De-soldering and soldering will be required.
Выберете то, что вам нужно
Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Refer to this link for proper de-soldering and soldering techniques.
Pull the capacitor from the other side of the circuit board once the solder is liquified.
Еще один человек закончил это руководство.
One Comment
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
