Введение
The Neutab N7 Pro has a dual camera. The gadget comes with a back camera of 2 MP and a front camera of 0.3 MP. The Neutab N7 camera can sometimes break or malfunction, and must then be replaced to continue to be able to take pictures and video. Use this guide to replace the camera.
Выберете то, что вам нужно
Insert plastic opening tool and pry back case away, slowly moving the plastic opening tool along the device.
Locate the camera unit and note where it is attached to the motherboard.
Use a black nylon spudger to remove the adhesive holding it onto to the motherboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a black nylon spudger or tweezers to release the connector holding the camera ribbon cable in place.
Carefully pull the ribbon cable out, removing the camera from the motherboard.
Еще один человек закончил это руководство.
