Введение
Your New Nintendo 2DS XL may need to have its motherboard replaced at some point in its life. This guide aims to provide step by step instructions on how to safely and effectively replace the motherboard. Before working on your New Nintendo 2DS XL, make sure the AC adapter is disconnected from the New Nintendo 2DS XL and that it is completely powered off.
Выберете то, что вам нужно
Before starting the disassembly, remove
The stylus
Any game cartridge
The SD card
Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
Using a spudger, separate the back panel from the front casing by gently prying around the panel.
There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
Using a spudger, lift out the battery.
Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
There are 8 ribbon cables that need to be removed as shown in the picture.
For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
Remove the seven 4.4 mm screws using a J00 Phillips screwdriver bit.
Remove the motherboard from the device.
9 участников успешно повторили данное руководство.
4 Комментариев
On step 6, what is the top left circled connector for?
The screen on the device I am repairing keeping going black and this connector is damaged. (it doesn’t clamp shut)
Can anyone recommend where to buy a replacement board connector?
This doesn’t actually give ALL the tools you need. You can’t use a Tri point screwdriver on the CROSS screws that are in the pictures on the motherboard.
I know this might be a year too late, but the tri point is required for removing the back plate of the system. If you don't have a small philips head laying around your house, idk what to tell ya
Followed on a 2ds having bad input feedback, no major issue. screws on motherboard are cross so you need a small one (most diy nintendo kits have one) and a small clamp (like the one in pictures) is mandatory for the 7 small cables. there is something a bit tricky regarding volume button which is a bit hard to get back in place when you reassemble the console, take care of pushing the inner slider to the most far position for easier mounting.
