New Nintendo 3DS XL 2015 Upper Screen Replacement
Выберете то, что вам нужно
  1. New Nintendo 3DS XL 2015  Upper Screen Replacement, Battery: шаг 1, изображение 1 из 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 2, изображение 1 из 1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 3, изображение 1 из 1
    • Once the screws are loosened, pry open the back cover.
  4. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 4, изображение 1 из 1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
    • Remove the SD card by pressing it in with your thumbnail until it clicks and partially ejects, then pull it out.
  5. New Nintendo 3DS XL 2015  Upper Screen Replacement, Motherboard: шаг 5, изображение 1 из 1
    • Using a JIS #00 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
  6. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 6, изображение 1 из 2 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 6, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
  7. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 7, изображение 1 из 3 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 7, изображение 2 из 3 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 7, изображение 3 из 3
    • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
    • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
  8. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 8, изображение 1 из 1
    • Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
  9. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 9, изображение 1 из 1
    • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the Circle Pad ribbon.
    • The cable folds over itself and enters the ZIF connector from the left side, but the connector's locking flap flips up from the right side. A common error here is to try pulling up on the same side as the cable is on, when that could break the connector.
    • Slide the ribbon out of the ZIF connector.
    • It may be easier to unscrew and remove the Circle Pad first, then try disconnecting the cable. Similarly, when reinstalling the Circle Pad, you can reconnect the cable first and then put the unit back into place.
  10. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 10, изображение 1 из 1
    • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
  11. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 11, изображение 1 из 1
    • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
  12. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 12, изображение 1 из 1
    • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Use a pair of tweezers to disconnect the single ribbon connector.
    • Don't do what we did -- be very careful not to pull on the red cable.
  13. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 13, изображение 1 из 3 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 13, изображение 2 из 3 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 13, изображение 3 из 3
    • Using tweezers, gently pull the four marked ribbons out of the ZIF connectors along the sides of the motherboard.
    • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them!
    • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • This one ribbon connector may also have a plastic clamping flap, but it's not like the others, rather it's similar to the one used for the Circle Pad. Gently flip up the flap on the side opposite the ribbon cable to remove the cable.
    • This connector was previously listed among the ones that do not have locks, however on most if not all systems, it actually does have one. Trying to remove or reinsert this cable without unlocking it will damage the cable, requiring a replacement of the Touch Screen's digitizer. Fortunately, the LCD uses other ZIF connectors, so that should still be fine.
    • If, on your system, this connector does not have a lock after all, do not pull up on the flap! It should come up easily; if it doesn't, it probably isn't meant to lock, but instead just hold the cable in with friction. In that case, try gently pulling the cable out of the connector.
    • When reassembling the device, be sure to flip the ZIF clamps back down.
    • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
  14. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 14, изображение 1 из 1
    • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
  15. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 15, изображение 1 из 2 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 15, изображение 2 из 2
    • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
    • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Note which way the ribbons slide into their connectors carefully, as they are different.
  16. New Nintendo 3DS XL 2015  Upper Screen Replacement, Top Display Casing: шаг 16, изображение 1 из 2 New Nintendo 3DS XL 2015  Upper Screen Replacement, Top Display Casing: шаг 16, изображение 2 из 2
    • Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing.
    • Underneath the rubber is a silver sticky
    • Using the PH00 screw driver, remove the screws.
  17. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 17, изображение 1 из 2 New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 17, изображение 2 из 2
    • From the hinge, slide the outer portion of the top shell so that it separates from the inner portion.
    • This step was edited recently because the previous version was risky. It told people to use a spudger and slide it around the edges. DO NOT DO THIS!!! It will snap tabs off!
    • The casing will become loose, and just lift the casing off.
  18. New Nintendo 3DS XL 2015  Upper Screen Replacement, Upper Screen: шаг 18, изображение 1 из 2 New Nintendo 3DS XL 2015  Upper Screen Replacement, Upper Screen: шаг 18, изображение 2 из 2
    • Make sure that all the taped parts are untaped from the screen and moved onto the side.
    • Using a plastic spudger, slightly lift it from underneath the lips and move it around the screen.
    • Once it is loose, lift the screen carefully.
  19. New Nintendo 3DS XL 2015  Upper Screen Replacement: шаг 19, изображение 1 из 1
    • The cables to the LCD are attached to the lower part of the 3DS' motherboard.
    • Be careful to avoid pulling the cables through the 3DS to prevent further damage.
    • Make sure to replace all cables to the correct location.
Заключение
15 человек успешно провели ремонт по этому руководству.
Ryan Butler
Участник с: 02/09/16
1 882 Репутация
Автор 9 руководств
Команда
iFixit, Team 1-1, Weber Winter 2016 Участник iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 членов
Автор 38 руководств
15 Комментарии к руководству
I am lost, where is the rest of the guide?
Jo Jones - Ответить
Is it possible we could get a link to a screen replacement?
Rupin Soland - Ответить
Almost every guide on the internet skips over getting ribbon-cable through the hinge…
Devin Shrhs - Ответить
and its the step that gets messed up the most so that may be why since you have to roll up the ribbon to get it through the hinge giving it a good chance of breaking the ribbon. Sucks because the only way to tell is to hook it all back up to see if it worked.
Jacob -
This guide is WORTHLESS - it’s ''cut-out in the middle'' at step 19 and in the most important part (ribbons)!!! I’ll make my own guide (possibly this year) This is a joke…
Sebastian - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 61
За последние 7 дней: 593
За последние 30 дней: 1,619
За всё время: 56,875
