Введение
This guide will show you how to remove the pneumatic panel for further disassembly and replacement. For some helpful tips, go to page 62 in the user manual.
Выберете то, что вам нужно
Place device so that the top cover is facing you.
Open the top cover.
Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
Pull up and remove the flexible rubber exhalation outlet boot (push fit).
Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
Remove the 2 screws and washers securing the manifold/mixer assembly
Gently pull each flow sensor straight out from the servo valve, (the flow sensor push-fits into the servo valve port).
Disconnect the flow sensor cable from its 10 pin connector at the underside of the flow sensor PCB and lift out the flow sensor.
Remove the screw and washer that secure the exhalation manifold support to the pneumatic panel.
Pull up on the exhalation valve guide block to remove it from the pneumatic box.
Remove the standoff and five screws and washers that secure the pneumatic panel to the pneumatic box.
Lift the pneumatic panel out of the box, and from the underside, detach all tubes and the heater wires that connect to the analog PCB.
