Nextbook 8 Screen Replacement
Выберете то, что вам нужно
  1. Nextbook 8 Screen Replacement, Battery: шаг 1, изображение 1 из 2 Nextbook 8 Screen Replacement, Battery: шаг 1, изображение 2 из 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Screen Replacement: шаг 2, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 2, изображение 2 из 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Screen Replacement: шаг 3, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 3, изображение 2 из 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Screen Replacement: шаг 4, изображение 1 из 1
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Screen Replacement: шаг 5, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 5, изображение 2 из 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Screen Replacement, Screen: шаг 6, изображение 1 из 1
    • Remove the silver and gold sticker at the bottom of the device.
    • Hold the brown circuit board down with your finger while you remove the sticker
  7. Nextbook 8 Screen Replacement: шаг 7, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 7, изображение 2 из 2
    • Use a spudger to lift up the black tabs on the three ZIF connectors.
    • Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
  8. Nextbook 8 Screen Replacement: шаг 8, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 8, изображение 2 из 2
    • Remove the 5 black screws on the motherboard.
    • Carefully lift the motherboard off of the device and remove.
  9. Nextbook 8 Screen Replacement: шаг 9, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 9, изображение 2 из 2
    • Remove the two screws that hold the brackets in place.
    • Remove the two silver brackets that hold the screen in place.
  10. Nextbook 8 Screen Replacement: шаг 10, изображение 1 из 2 Nextbook 8 Screen Replacement: шаг 10, изображение 2 из 2
    • Remove the one silver screw on the small green circuit board at the bottom of the device.
    • Set aside the small circuit board for now.
  11. Nextbook 8 Screen Replacement: шаг 11, изображение 1 из 1
    • Remove the two silver screws from the bottom of the device.
  12. Nextbook 8 Screen Replacement: шаг 12, изображение 1 из 3 Nextbook 8 Screen Replacement: шаг 12, изображение 2 из 3 Nextbook 8 Screen Replacement: шаг 12, изображение 3 из 3
    • With the device face down, use a spudger to lift the screen off of the glass from the right side.
Заключение
21 участников успешно повторили данное руководство.
Dylan Wiese
Участник с: 03/11/15
1 853 Репутация
Автор 5 руководств
Команда
Colorado Springs, Team 5-1, Panko Spring 2015 Участник Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
3 членов
Автор 10 руководств
Один комментарий
where do I find the actual screen though
WiKiT Woo WoNKa - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 23,856
