Выберете то, что вам нужно
Use the plastic opening tool to pry apart the front and back covers of the Nextbook
Continue prying until the front and back covers are completely separated. Use the suction cup if necessary to pull apart
We recommend using an extra plastic opening tool to maintain your opening
Once the front and back covers have been separated, set the back cover down and examine the interior of the Nextbook
Remove the various pieces of masking tape
Carefully peel the battery pack off, starting from the outer edges
It is held down by an adhesive going diagonally across the back
Removing the battery will allow you to access the screws holding the chip in place
Remove the entire chip by severing small adhesive strips along the edges and pulling the chip away from the frame
Carefully peel away the black tape with copper detail that is holding the chip to the device
Locate the camera
The camera will be a small black square directly behind the camera lens visible on the front side of the Nextbook
Pry the camera out of the front cover with the plastic opening tool
