Инструменты
Запчасти
Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
Pull the the plastic backing off the display assembly using your hands.
Lift latch on front-facing camera connector.
Pull the connector toward the top of the device and remove the front-facing camera.
