Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
Pull the the plastic backing off the display assembly using your hands.
Detach the three connector ribbons passing over the battery using the plastic opening tool.
Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
Disconnect the battery by lifting it upward and pulling it away from the connector.
Disconnect right speaker connector ribbon from logic board.
Lift the speaker out by pulling up on its corner.
Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
Unseat the small vibrator motor by gently applying upward pressure with a spudger.
Lift the assembly by gently applying upward pressure with the spudger on the assembly.
Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
