Выберете то, что вам нужно
Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
Pull the the plastic backing off the display assembly using your hands.
Be carefull with the power button cable. Don’t insert the plastic tool in this zone
Some instruction guides also suggest optional use of a suction cup with which to tug on the glass while separating the plastic backing. I found this helpful. Also, if you have a spudger of more rigid plastic, use that one here. My blue spudgers got chewed up pretty badly during this process.
Detach the three connector ribbons passing over the battery using the plastic opening tool.
The left two connectors flip up from the cable side. The right connector flips up from opposite the cable.
Note that you don’t just pull the ribbons out. There is a clamp on each connector that needs to be prised opened, releasing the ribbon. This was helpful: https://youtu.be/yru4k62qdEU?t=302
You sir, are a true humanitarian!!!
Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
Disconnect the battery by lifting it upward and pulling it away from the connector.
When reassembling reconnect the data ribbon cables first, then connect the battery connection last so that you’re not plugging in data lines while powered. Ideally you’d disconnect the battery first but that’s a bit hard with the design so you just have to try to ensure it’s switched off first.
Disconnect right speaker connector ribbon from logic board.
Lift the speaker out by pulling up on its corner.
Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
Unseat the small vibrator motor by gently applying upward pressure with a spudger.
Lift the assembly by gently applying upward pressure with the spudger on the assembly.
Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
5 участников успешно повторили данное руководство.
