Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:SIM Card Eject Tool$2.99-
Power off the phone, by long-pressing the power button and touching Power off.
Remove the SIM tray using the SIM Card Eject Tool.
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$5.49-
Remove the two screws from the bottom of the phone with a T5 Torx Screwdriver.
Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
Remove the two 1.8 mm Phillips screws holding down the battery connector.
Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
Инструмент, используемый на этом этапе:Plastic Cards$2.99-
Remove the blue tape that secures the white antenna cable to the battery.
Using a spudger, carefully disconnect the white antenna cable.
Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Using a spudger, pop off the gray connector on the top right of the motherboard.
Gently lift the audio jack upwards and to the left to remove it from the motherboard.
The audio port will likely lift out together with the ambient light sensor rubber cap.
Remove the cap from the old part and move it to the new one. Ensure the cap stays in place when installing the new audio port into the phone.
26 участников успешно повторили данное руководство.
Один комментарий
where can I order the original connector on my Nexus 4? With delivery to the Crimea.
Grateful for the answer in advance.
