Введение
This guide shows how to remove and install the phone's camera located in the top left-hand corner of the motherboard.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:SIM Card Eject Tool$2.99
Power off the phone, by long-pressing the power button and touching Power off.
Remove the SIM tray using the SIM Card Eject Tool.
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$5.49
Remove the two screws from the bottom of the phone with a T5 Torx Screwdriver.
Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
Remove the two 1.8 mm Phillips screws holding down the battery connector.
Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Remove the blue tape that secures the white antenna cable to the battery.
Using a spudger, carefully disconnect the white antenna cable.
Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Gently pry the metal tab up using a spudger, and lift up the disconnected black flap.
With a spudger, carefully pry up the black tab connecting the camera to the motherboard.
Lift up the camera from the socket.
8 участников успешно повторили данное руководство.
