Nexus 5 Antenna Cable Replacement
Выберете то, что вам нужно
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: шаг 1, изображение 1 из 1
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: шаг 2, изображение 1 из 3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: шаг 2, изображение 2 из 3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: шаг 2, изображение 3 из 3
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: шаг 3, изображение 1 из 2 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: шаг 3, изображение 2 из 2
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: шаг 4, изображение 1 из 3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: шаг 4, изображение 2 из 3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: шаг 4, изображение 3 из 3
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: шаг 5, изображение 1 из 2 Nexus 5 Antenna Cable Replacement, Reassemble the Device: шаг 5, изображение 2 из 2
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
Финишная прямая
Еще один человек закончил это руководство.
Tyler Caldwell
Участник с: 12/07/17
184 Репутация
1 руководство автора
Команда
IUPUI, Team S1-G1, Baechle Fall 2017 Участник IUPUI, Team S1-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S1G1
2 членов
Автор 6 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 3,029
