Nexus 5 LCD Screen & Digitizer Assembly Replacement
Выберете то, что вам нужно
  1. Nexus 5 LCD Screen & Digitizer Assembly Replacement, SIM Card: шаг 1, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement, SIM Card: шаг 1, изображение 2 из 2
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 2, изображение 1 из 1
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
  3. Nexus 5 LCD Screen & Digitizer Assembly Replacement, Back Cover: шаг 3, изображение 1 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement, Back Cover: шаг 3, изображение 2 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement, Back Cover: шаг 3, изображение 3 из 3
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
    Wireless QI and NFC.
    Once I have put everything together with the new battery in place, I have as last replaced the plastic back cover, snapping all the clips back around the edges of the phone. Alas, I was quick to realise the QI Wireless charging has ceased to work.
    I almost blamed the battery, or worse, me.
    QUICK TIP: there is actually another clip in the middle of the plastic back cover - just press with your thumb just above the 'S' in NEXUS emblem and, voila! Snaps back in.
    Wireless charge and NFC - works, once again.
    cwioro - Ответить
    you just saved me like 30 bucks. thank you so much.
    Robert Nolan -
    + 1, had the same issue and pressing just near the S fixed it! Thanks a lot!
    nicco82 -
    Just a me too, I had to press above the S and it was quite a snap
    Erik Karlin -
    There seems to be two contacts that snap into place. One is in line with the led pretty much in the middle of the phone and the second one in line with the camera lens on the opposite side to the lens. The middle one for me snapped pretty lightly, but the side one required a bit more pressure. After that the nfc started working again. Thanks for posting this!
    Dennis Millner -
    Is it hard to remove the battery door? Worried I might damage it.
    Ash - Ответить
    When I openend the back cover I damaged two clips. One about 2.5cm (1 inch) below the volume controls and one on the other side about same height. The cover fits good without those two but on one side there is a small gap where the clip broke. But I have a hard cover protector on my phone so it's not that bad.
    simonlwheeler - Ответить
    The case around the sim slot is pretty thin and easy to break, best to avoid using the pry tool at this point.
    Aled Morris - Ответить
    Excellent tip, should be included in the main guide.
    fprades - Ответить
    Hey Author, i need to ur expert advice...i replaced my nexus 5's back cover. since the new one did not have the vibrators battery i had to take it from the old one and connect it to the new one...on removing i noticed that it was stuck to the cover by a glue
    Question: what glue to use to hold the battery to the cover?
    suwaid akbar - Ответить
    Any adhesive will do. I used a hot glue gun. You shouldn't need expert advice to figure that out. Use your head.
    tjt263 -
    The case around the volume control is also pretty thin.... I broke mine prying so avoid the pry there too.
    Also my back had glue at the bottom and I haven't seen mentioned
    kornerson - Ответить
  4. Nexus 5 LCD Screen & Digitizer Assembly Replacement, Midframe: шаг 4, изображение 1 из 1
    • Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
    • Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
    • To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
    I had a bit more success with the Phillips #000.
    Ross Light - Ответить
    Step 4 (removing the screws in the protecting plate) needs to happen before Step 2 ( removing the connectors)
    Esteban Valles - Ответить
    These were Y0 screws for me.
    Benjamin Hollway - Ответить
    Same here, Benjamin
    Ítalo Masserano -
    Me three on the Y-type screw heads.
    Jamoross -
    Same for me. I had more luck with the two screws in the middle with #000.
    Rewarp - Ответить
  5. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 5, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 5, изображение 2 из 2
    • Remove the midframe from the phone.
    • Examine the midframe and the back cover and you'll find three very small snap attachment points for the back to the midframe. These ensure that the NFC and wireless charging antenna contacts connect with the corresponding spring connectors on the motherboard. Ensure the snaps are in good condition.
    There's also some adhesive holding the motherboard cover plate in place, below the camera. Has to be pulled a little stronger than expected.
    tkatona - Ответить
  6. Nexus 5 LCD Screen & Digitizer Assembly Replacement, Battery: шаг 6, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement, Battery: шаг 6, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Spudger
    $2.99
    Купить
    • Use the flat end of a nylon spudger to disconnect the battery connector.
  7. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 7, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 7, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable and pull it away from the battery.
  8. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 8, изображение 1 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 8, изображение 2 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 8, изображение 3 из 3
    • Use a plastic opening tool to pry the battery out of its housing.
    • You may need to use a heat gun to apply a small amount of heat to soften the adhesive below the battery.
    • Do not puncture or bend the battery.
    • If replacing the battery, bag the old battery up and recycle responsibly at a suitable location.
    This part is very delicate. The adhesive is pretty solid and I did puncture the battery. It is dangerous and the battery should be replaced with a new one.
    Christophe De Wolf - Ответить
    Thanks Chris for the notice. I have added a warning on your advise. Do you think about any better way to unglue the battery?
    Gaetan -
    Like another user, I had already taken my cover off plenty of times prior to. The issue of course was removing the battery. I purchased the opening tools and spudger and used them but to no avail. I ended up using a flat tip screwdriver and got the battery out within seconds with no puncturing.
    gnewton16 - Ответить
    I'll second the flathead screwdriver. Tried different plastic tools only to damage both the battery and a spring connector on the phone. With the flathead screwdriver battery came out quite easily lifting from the bottom end. There is an adhesive tape holding the battery firmly in place that retains the adhesive surface after removing the battery, so the new battery should attach properly.
    Dennis Millner -
    Why do you need to remove the battery at all? Just replaced my rear camera without removing it. I mean, I realise that removing the power source would have been safer, but would it be enough just to detach the motherboard connector?
    eyusupov - Ответить
    This guide is about the REPLACEMENT of the battery, and for that it seems necessary to remove it first. ;-)
    biharikristof -
    Do you need to apply adhesive to the new battery to keep it in place?
    no there is generally glue remaining and it stays in place pretty good
    mmoodley10 -
    This was fantastic, thank you! I had never done anything like this before! You just saved me some money and also taught me something :D
    anagarciasebastia - Ответить
    to make Qi work, you have to press the cover really everywhere afterwards. The contacts for Qi are between th Nexus "S" and the camera. Sometimes the Qi loading needs some time to work - I assume the battery needs to expand after a few loading cycles...
    Apeiron - Ответить
    The first time I tried to replace the battery I ended up breaking off the tab on the new battery. It needs to be bent properly to fit into the socket on the phone. The second time, I connected the tab t the socket BEFORE placing the new battery into the area of the phone where it sits. Then I was able to use the plastic tool to correctly bend the connector.
    John Goldin - Ответить
    I have replaced the battery and after doing this there is a flashing red light. does this mean its just charging from empty or have I done something wrong? Do i need to press any buttons to make sure its charging properly? do i need to re open it up to check connections? what do i do? there is no mention of whether it should turn back on or what it should do/how long it will take to be up and running again.
    Bambipeach - Ответить
    I had the same "problem", though I had misplugged the battery. Just wait for a couple of minutes and your phone should start to charge. Also, I've been told to fully charge and discharge the battery 2-3 times before using it.
    Steve Simard -
    Be extremely careful while prying out the battery. I had damaged a Nexus 4 battery while trying to do this, and smoke started coming out. If you search youtube you can see how a punctured Li-ion battery can explode in seconds.
    Abhi B - Ответить
    Why not remove the battery by pulling on the small ribbon cable at the top?
    Matt Szczublewski - Ответить
    When you take out the battery, there are some sort of black tape (adhesive) around the inner circle of the empty battery chassis. I might have been too rough and taken the black tape out completely. Now with the newly replaced battery, Nexus 5 won't charge or power on. Does anyone know what the black tape is for? is it the reason or something else?
    Gracie - Ответить
    I found out that the heavy duty suction cup I bought to replace phone screens works quite effectively at removing the battery without bending or damaging it. Of course, this was being used on a battery that was itself a replacement of the original, so the adhesive may have weakened significantly.
    Rewarp - Ответить
  9. Nexus 5 LCD Screen & Digitizer Assembly Replacement, Motherboard: шаг 9, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement, Motherboard: шаг 9, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the left antenna cable.
  10. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 10, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 10, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the right antenna cable.
    • These must be firmly secured during reassembly. Failure to secure the antenna connections will affect your reception and call quality.
  11. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 11, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 11, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the ribbon cable that connects rear-facing camera to the motherboard.
  12. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 12, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 12, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the front camera ribbon cable.
  13. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 13, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 13, изображение 2 из 2
    • Gently lift the motherboard up and out of the device.
  14. Nexus 5 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: шаг 14, изображение 1 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: шаг 14, изображение 2 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: шаг 14, изображение 3 из 3
    • Insert a spudger into an opening between the daughterboard and plastic housing.
    • Lift the daughterboard cover up and off the frame.
    • If Jeff, Max, Cole, Corey, Guy, Leslie, Harry, or Matt were already here, consider searching your device for surveillance bugs.
  15. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 15, изображение 1 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 15, изображение 2 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 15, изображение 3 из 3
    • Use the flat end of a nylon spudger to pry the white and black antenna connectors up off the daughterboard.
  16. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 16, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 16, изображение 2 из 2
    • Use the flat end of a nylon spudger to pry the digitizer ZIF connector up off the daughterboard.
  17. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 17, изображение 1 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 17, изображение 2 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 17, изображение 3 из 3
    • Insert a nylon spudger into an opening beneath the daughterboard and pry it up to free it from the frame.
    • The frame around the micro-USB port is very fragile—take care not to break this small plastic bridge.
    • Do not disconnect the daughterboard entirely. Gently fold it to the side of the phone.
    I want to remove/replace the daughterboard/charging assembly, completely. The RH side appears to adhere to the chassis. What's the best method for separation?
    tjt263 - Ответить
  18. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 18, изображение 1 из 1
    • Use an iOpener or heat gun and carefully apply heat to the digitizer panel to soften the adhesive that secures it to the frame.
    • Hold the heat gun approximately 8-10 inches from the device and apply heat in a gentle back-and-forth motion.
  19. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 19, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 19, изображение 2 из 2
    • Work the flat end of a nylon spudger under the digitizer panel. Gently pry the panel up to free it from the adhesive.
    • The phone may be too hot to touch from the heat gun. Allow a moment for it to cool to avoid burning your fingers.
  20. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 20, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 20, изображение 2 из 2
    • Use a heat gun or an iOpener to soften the adhesive along the edges of the screen.
  21. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 21, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 21, изображение 2 из 2
    • Use a suction cup to firmly pull the screen away from the frame.
    • The Nexus 5 has a very thin layer of adhesive. This should not require excessive force. Apply additional heat as needed to soften the screen adhesive.
  22. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 22, изображение 1 из 2 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 22, изображение 2 из 2
    • Insert an opening pick in the gap between the screen and the frame.
    • Work the opening pick along the edges of the screen to break any remaining adhesive and free the screen assembly.
  23. Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 23, изображение 1 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 23, изображение 2 из 3 Nexus 5 LCD Screen & Digitizer Assembly Replacement: шаг 23, изображение 3 из 3
    • Gently remove the LCD screen and digitizer assembly.
    • Carefully feed the digitizer ribbon cable through the frame.
    The crucial step to glue back the new screen is missing.
    Could you add an equally detailed description of this step ?
    Thanks !
    Anton - Ответить
    Thank you. We need this addressed it’s been 3 years.
    Sum Guy -
    I’ll second this request for a detailed description of gluing the new screen.
    Oscar Valdez - Ответить
    ^THIS!
    Oscar and Anton are on point.
    I hate your site comment filters and settings too, but just focus on not screwing things up and making pro right to repair people look like jackasses when we have corporate and possibly state sponsored efforts to undermined us already.
    Sum Guy -
    WHAT THE !&&* IS WRONG WITH YOU? Am I just suppose to follow the directions in reverse?!
    Sum Guy - Ответить
    I’ll make it easy on the mods, I did a two second google search to find the info and I am linking three videos here, here, and here.
    If you are a mod, make sure the guy in charge of writing these things takes a few minutes out of his day to finish what he started three years ago, and if that is too hard the videos are right here for him to watch and he can just copy what he sees.
    Sum Guy - Ответить
    Hello everyone. I proposed some edits to this guide to include the few critical steps consisting of: 1) Cleaning the frame; 2) Applying the screen adhesive; 3) Applying the screen. The remainder of the reassembly can be done quite easily by just following the instructions in reverse. I do not know how quickly my proposed edits will be included in the “Verified Guide”, but you can see browse them in the “unverified version” here. Any feedback over there is of course welcome.
    Patrick Finnerty - Ответить
Заключение
44 участников успешно повторили данное руководство.
Richard
Участник с: 02/07/17
30 037 Репутация
Автор 11 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
10 Комментариев
This is a nice guide to understand how to disassemble and assemble your Nexus 5. 95% can be done with this guide.
Tip: read the comments!
My own tips are:
1) Search for instructions how to use glue or double sided adhesive tape. It's a must if you want succesfully put everything back together
2) You need to transfer the speaker protection from the inside of the glass to the new glass
3) The same needs to be done with with a white rectangle. It has something to do with your LED-light at the bottom.
Saw these tips in this YouTube video https://youtu.be/jQS618ayL5w
Jeroen Meyer - Ответить
Thanks for the extra tips, Jeroen! These two steps can be found at 2:50 of the video for those who want to skip right to it. ;)
We do supply the tape as well: Tesa 61395 Tape
By the way, does the guy in this video remind anyone else of Thrawn from Star Wars Rebels (aka Lars Mikkelsen?)
Richard -
Hey, what size do I need for the tape? Is the mm size referring to width or thickness?
I assume it’s width and I need 1mm or 2mm to repair my Nexus 5, but which one?
Carsten Pfeifer -
I need a little help with this tutorial. I’ve bought a second hand N5 where someone replaced the screen, now the display lifts off slightly in the bottom left corner of the device. Pushing it back will only hold it in for a few minutes. Should I slide a tiny piece of double-sided adhesive tape underneath, or rather some modelmaking glue?
Ste Se - Ответить
The new screen is not adhered as the old one was.. not sure what I would use for that. Not terribly important for me since it sits 99% flush, and lives in an enclosed case, but the guide should probably mention this.
Kristen McWilliam - Ответить
there is no reason to fully disassemble your phone just to replace the screen all you have to do is pull off the back pannel unscrew the speaker/mic housing assembly then take it off, dissconnect the screen connector under that and lift out the little breakout board where all the connections to the phone go at this point pry off the bad screen and put in a new one plug it in and glue it down with something like rubber cement reassemble and done. I have done this about 50 times with my nexus 5. I refuse to be careful with my phone.
Christopher Deming - Ответить
note: do not use super glue to glue in your screen, you want something rubber cementy because it will hold your screen good but it can be peeled away, and any excess is easally removed. I personally use Loctite “flexable adhesive” for “ vinyl fabric & plastic”.
I like to put it under some slightly heavy books wile it drys
oh and don’t forget your speaker grill for the phone speaker
Is it possible to replace the digitizer and re-use the factory screen? The screen on my phone is perfect with no scratches or cracks and I would hate to replace it with some knock-off glass. My phone just randomly stopped responding to touches but is otherwise pretty mint for being so old.
Michael Guy - Ответить
Do NOT use the ifixit display adhesive to attempt this repair, not only are there no instructions, it is really easy to remove the aluminum foil which is responsible for the backlight. I nearly destroyed my new display digitizer trying to attempt this repair. Get some epoxy from home depot, don’t waste your time
Wes - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 58
За всё время: 34,918
