Введение
This guide will show you how to replace your Nexus 5 SIM card.
Выберете то, что вам нужно
Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
Push the tool into the hole until you see the card pop out.
Инструмент, используемый на этом этапе:Tweezers$4.99
Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
2 человек успешно провели ремонт по этому руководству.
