Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is used to replace the back cover of the device or as a precursor to accessing the internal components of the device.
Выберете то, что вам нужно
Power down your device.
Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time.
Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
16 участников успешно повторили данное руководство.
4 Комментариев
Step left out. ifixit.com video on Youtube show use of craft knife as first step to get into very tight case fitting, then the use of plastic pry tool to go around releasing the backcover.
I didnt read the comment about it being tight and using a knife, until I had damaged the prying tools :-(
How do u take off the cover do u have to have that tool
I had very little problem prying of the back of my nexus 7 2012. Once you get the first corner done, the rest comes pretty easy.
I ended up using an old hotel keycard as a spudger and it worked fine.
I needed access to the cables that connect the touchscreen to the motherboard so that my touch screen would respond.
Worked like a charm!
