Введение
Use this guide to replace the antenna board on your Nexus 9.
Выберете то, что вам нужно
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
The antenna board should now lift free of the motherboard.
