Выберете то, что вам нужно
Using the plastic opening tools, pry the left bottom corner of the battery up.
Remove the two Torx T5 screws.
Remove the one Philips #00 screw.
Using the plastic opening tool, pry up the battery housing upwards.
Push pry tool down, undoing the plastic tab.
Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip)
Swap the spudger to the other side of the cover base. Pry upwards. (fix?)
Grasp the camera module and pull up.
Еще один человек закончил это руководство.
