Введение
installing the flash
Выберете то, что вам нужно
Using the plastic opening tools, pry the left bottom corner of the battery up.
Remove the two Torx T5 screws.
Remove the one Philips #00 screw.
Using the plastic opening tool, pry up the battery housing upwards.
Push pry tool down, undoing the plastic tab.
Insert the spudger under the bottom of the flash board
Twist the spudger to lift and release the flash board.
2 участников успешно повторили данное руководство.
