Выберете то, что вам нужно
Using the plastic opening tool, push the blade into the space between the case and lower cover.
Turn the opening tool slightly, the lower cover will detach on that side.
Repeat on other side of the seam.
The lower cover will slide off.
Remove the one T5 Torx screw
Remove the one #00 Philips screw
Lift up the end of the antenna housing and slide it outwards.
The vibrator is located on the back of the antenna housing.
Use the spudger to pry up on the axle of the motor.
