Введение
This is a relatively easy repair to make to your Q. Follow the prerequisite for removing the inner dome daughterboard to get started.
Выберете то, что вам нужно
Squeeze and pull to pop the cap off of the Nexus Q.
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
Еще один человек закончил это руководство.
