Введение
Replacing this antenna is about the easiest repair you can make to your Nexus Q
Выберете то, что вам нужно
Squeeze and pull to pop the cap off of the Nexus Q.
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Еще один человек закончил это руководство.
