Введение
This guide will help you replace the SIM Card board.
Запчасти
Никакие детали не требуются.
  1. Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Remove the rear panel from the Nexus S.
    • Remove the rear panel from the Nexus S.
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    • Lift and remove the rear inner frame from the Nexus S.
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
    • Lift and remove the SIM Card board out of the Nexus S.
    • SIM Card board remains.
Заключение
14 участников успешно повторили данное руководство.
Комментариев: 2
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 14
За всё время: 8,437
