Введение
This replacement may be necessary if all other options have been exhausted.
Выберете то, что вам нужно
Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
Remove the screws under the flaps covering the HDMI and mini USB ports.
Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
Use the plastic opening tool to pry off the connectors shown
Using your finger, pry off the connection flap.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, pull out the shown connectors
Pull back the black switches holding the connecting ribbons in place, and pull out the ribbons.
Remove the motherboard.
Еще один человек закончил это руководство.
