Выберете то, что вам нужно
Remove 2 screws
Open plastic LCD connector cover
Lift FPC connector latch
Detach LCD FPC
The FPC cable is inserted from right side of this photo.
Insert a fine tip tweezer or any thin flat tip tool under the latch, and gentally lift it.
The latch rotates CCW for about 90 degrees
Left side, in connector bay, remove 2 screws.
Bottom, reomve 2 screws
Right side, remove 1 screw
Инструмент, используемый на этом этапе:Tweezers$4.99
Peel tape with an isolated tool (plastic crowbar, plastic tweezers, toothpick etc). DO NOT USE metal tweezers.
Use a 2-10kohm 5W resistor to discharge flash condenser, for atleast 10 seconds.
Check voltage across 2 points. Make sure it's below 5V DC
Flash solenoid and detect
Microphones and AF assistant LED
Keypad
Switches
NFC
WiFi and Bluetooth, Lens(back)
CMOS sensor
LCD
Desolder Flash Condenser
Desolder flash xenon tube
