Запчасти
Никакие детали не требуются.
  1. Remove the screw located near the speaker port using a Phillips 00 screwdriver.
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Turn camera upside down so that the battery compartment is facing you.
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Rotate the camera to the opposite side where the A/V outlet is located.
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Turn the camera so that the Wi-Fi adapter is facing you.
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Using a plastic opening tool, pry the front casing of the camera. Continue this motion all around the front casing of the camera. Gently pull apart the front casing from the rest of the camera.
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Using the plastic opening tool pry the back casing of the camera.
    • Using the plastic opening tool pry the back casing of the camera.
  7. Orange ribbon is fragile
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Pull down the on the black latch to carefully separate the orange ribbon from the motherboard. Pull apart the orange ribbon and front casing from the rest of the camera.
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  10. Use plastic opening tool to carefully pry the LCD Screen from the camera. Use plastic opening tool to carefully pry the LCD Screen from the camera.
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  11. Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard. Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  12. De-solder the black and red wires from the mainboard.
  13. Continue by removing two screws from the back of the camera body.
    • Continue by removing two screws from the back of the camera body.
  14. Remove the screw connecting the wifi card cover to the front of the camera.
    • Remove the screw connecting the wifi card cover to the front of the camera.
  15. Remove the final screw connecting the Wifi card cover to the case.
    • Remove the final screw connecting the Wifi card cover to the case.
  16. Gently pull the Wifi card cover off of the camera body.
    • Gently pull the Wifi card cover off of the camera body.
  17. Remove the screw holding the Wifi Card to the camera body.
    • Remove the screw holding the Wifi Card to the camera body.
  18. Gently pull the WiFi card out of the camera.
    • Gently pull the WiFi card out of the camera.
  19. Continue removing screws from the outside of the camera body. Next pull the plastic side panel off of the camera body.
    • Continue removing screws from the outside of the camera body.
    • Next pull the plastic side panel off of the camera body.
    • Be extremely careful when holding the camera around the flash capacitor (circled in green), it is probably still charged, and it is very painful if you are shocked by it.
  20. Remove the two screws connecting the strap loop to the camera body. Remove the three screws from the left side of the camera body. Remove the screw by the shutter button.
    • Remove the two screws connecting the strap loop to the camera body.
    • Remove the three screws from the left side of the camera body.
    • Remove the screw by the shutter button.
  21. Remove screws from plastic side cover. Pull off plastic cover.
    • Remove screws from plastic side cover.
    • Pull off plastic cover.
  22. Carefully remove the back housing body from the camera. Carefully remove the back housing body from the camera.
    • Carefully remove the back housing body from the camera.
  23. Remove the five screws connecting motherboard to the camera body. Carefully detach the two ribbon cables from the motherboard by releasing the black plastic catch, then pull the cables gently upwards out of the connector.
    • Remove the five screws connecting motherboard to the camera body.
    • Carefully detach the two ribbon cables from the motherboard by releasing the black plastic catch, then pull the cables gently upwards out of the connector.
  24. Carefully de-solder the four connections to the motherboard.
    • Carefully de-solder the four connections to the motherboard.
Заключение
Joshua Avery
Участник с: 23.01.2012
31 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 3-28, Amido Winter 2012 Member of Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 1,180
