Выберете то, что вам нужно
Remove the screw located near the speaker port using a Phillips 00 screwdriver.
Turn camera upside down so that the battery compartment is facing you.
Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
Rotate the camera to the opposite side where the A/V outlet is located.
Unscrew and remove all four screws with a Phillips 00 screwdriver.
Turn the camera so that the Wi-Fi adapter is facing you.
Using a plastic opening tool, pry the front casing of the camera.
Continue this motion all around the front casing of the camera.
Gently pull apart the front casing from the rest of the camera.
Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
Pull apart the orange ribbon and front casing from the rest of the camera.
Use plastic opening tool to carefully pry the LCD Screen from the camera.
Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
Continue removing screws from the outside of the camera body.
Next pull the plastic side panel off of the camera body.
Remove the two screws connecting the strap loop to the camera body.
Remove the three screws from the left side of the camera body.
Remove the screw by the shutter button.
Remove the five screws connecting motherboard to the camera body.
Carefully detach the two ribbon cables from the motherboard by releasing the black plastic catch, then pull the cables gently upwards out of the connector.
