Введение
This guide demonstrates how to remove the image sensor from your Nikon COOLPIX P500 camera.
Выберете то, что вам нужно
Remove all the marked screws using a PH00 screwdriver.
Remove the two 3mm screws on the grip.
Remove the two 4mm screws on the side opposite the grip.
Remove the three 4mm screws on the base of the camera.
Remove the four 3mm screws on the base of the camera.
Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
Separate the two parts of the body of the camera slightly.
Release the two cables by lifting up their respective clips with a spudger.
Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
Remove the four labeled 4mm screws connected to the motherboard.
Remove the metal support.
Use a spudger to unlock the labeled connector ribbons.
Disconnect the labeled connector ribbons.
Use a spudger to unlock the two connector ribbons.
Disconnect the two connector ribbons.
Use a PH00 screwdriver to remove the two 2mm metal screws from the image sensor cover.
Use a PH00 screwdriver to remove the three 3mm screws holding the image sensor down.
3 участников успешно повторили данное руководство.
