Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the three 3x3mm screws attached to the rear casing.
Remove the 5x3mm screw holding down the panel on the side closest to the lens.
Remove the 3x2mm screw underneath the panel near the top of the camera.
Remove the 4x3mm on the opposite side near the selector wheel.
Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Pry the back panel away from the body of the camera, using the space you just opened up.
A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
Remove the three 3x3mm screws that attach the front casing to the bottom.
Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
Remove the final 4x3mm screw at the top of the camera near the lens.
Unscrew the three 3x2mm screws that attach the cables to the front casing.
Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
Once the lens assembly has been removed, the mother board cannot be disassembled any further.
