Введение
Something is wrong with the Navigation Panel? Try replacing it.
Выберете то, что вам нужно
Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
With the bottom of the camera facing you, slide the latch on the compartment to the left.
Swing the battery compartment door open.
Remove the 3.5 mm screw from the inside with a #00 Phillips screwdriver.
With the screen facing you, locate the two 3.5 mm screws on the left face of the camera. Remove them using a #00 Phillips screwdriver.
With the screen facing you, locate the three 3.5 mm screws on the right face of the camera. Remove them with a #00 Phillips screwdriver.
Locate the crease where the case comes together.
Using a plastic prying tool, pry at the line to remove the camera case.
Slide the yellow navigation panel to the right so that it can be lifted up.
Locate the magnet and copper tape on the left side of the camera.
Gently pull the copper tape off of the metal plate.
Lift the screen up and swing it to the right, exposing the circuit board underneath.
Detach the ribbon cable that is connecting the LCD screen and the circuit board.
Detach the ribbon cable connecting the navigation panel to the camera.
The navigation panel can now be removed.
