Nikon CoolPix P310 Sensor Replacement or Cleaning
Выберете то, что вам нужно
    • Remove all screws from the bottom, sides and top of the camera. All screws don't have the same size, be careful when replacing them.
    • Pull gently but firmly the back cover of the camera to remove it and reveal the inside.
  1. Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: шаг 2, изображение 1 из 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: шаг 2, изображение 2 из 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: шаг 2, изображение 3 из 3
    • Remove the plastic part with all buttons.
    • Lift up the the buttons block from the left side, to access its ZIF connector.
  2. Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: шаг 3, изображение 1 из 2 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: шаг 3, изображение 2 из 2
    • With a plastic spudger, open the ZIF connector and release the button block. It opens from the right side - the black part is to be gently lifted up.
  3. Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the Screen: шаг 4, изображение 1 из 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the Screen: шаг 4, изображение 2 из 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the Screen: шаг 4, изображение 3 из 3
    • Lift up the screen from the left side, to access its two ZIF connectors.
    • Open the small and the large ZIF connectors with a spudger.
    • The small connector is opened by lifting the black part.
    • The large connector is released thanks to the orange part. This longer connector needs to be opened carefully.
  4. Nikon CoolPix P310 Sensor Replacement or Cleaning, Accessing the main PCB: шаг 5, изображение 1 из 2 Nikon CoolPix P310 Sensor Replacement or Cleaning, Accessing the main PCB: шаг 5, изображение 2 из 2
    • Remove the screws maintaining the last metal protection.
  5. Nikon CoolPix P310 Sensor Replacement or Cleaning, Releasing the image sensor: шаг 6, изображение 1 из 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Releasing the image sensor: шаг 6, изображение 2 из 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Releasing the image sensor: шаг 6, изображение 3 из 3
    • Remove the 3 screws to release the image sensor PCB.
    • Release the ZIF connector lifting it up gently using a plastic spudger.
    • You can then remove the image sensor and clean it. Avoid to scratch the sensor or the inner lens glass, as these would be unrepairable damages.
Заключение
AlexFixeurs
Участник с: 06/20/15
1 210 Репутация
Автор 3 руководств
Команду
Fixeurs Участник Fixeurs
Business
1 член
Автор 5 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 4
За последние 30 дней: 27
За всё время: 944
