Введение
This guide is to be used to install the back cover in the event that it becomes damaged. A Phillips screwdriver will be needed to complete this installation.
Выберете то, что вам нужно
Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
Repeat the removal of the two screws on the other side of the camera.
Еще один человек закончил это руководство.
