Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide is to be used to install the battery in the case that the battery dies or no longer functions properly. A Phillips screwdriver will be needed to complete this installation.
Инструменты
Инструменты не указаны.
Запчасти
  1. Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Press orange clip to eject battery (battery not shown).
    • Press orange clip to eject battery (battery not shown).
  3. STUDY UNPLUGGED
    Battery Fix Kits for Mac
    Shop Fix Kits
    STUDY UNPLUGGED
    Shop Fix Kits
  4. While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  5. Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  6. Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Заключение
3 участников успешно повторили данное руководство.
Patty Richeson
Участник с: 11.03.2013
75 Репутация
Автор 4 руководств
Команда
Clemson, Team 12-5, Benson Spring 2013 Участник Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 410
