Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is to be used to install buttons in the case that the buttons are damage or are no longer functioning properly due to overuse. A Phillips screwdriver will be needed to complete this installation.
Выберете то, что вам нужно
Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
Repeat the removal of the two screws on the other side of the camera.
Using fingers, lift up button plate on the side closest to the LCD screen.
3 участников успешно повторили данное руководство.
