Введение
Replacing the front cover of a Nikon Coolpix 3500.
Запчасти
No parts specified.
  1. Unlatch the battery cover. Slide the cover out and flip it open.
    • Unlatch the battery cover. Slide the cover out and flip it open.
    • Remove the battery.
    • Gently remove the battery cover.
  2. Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Remove the two 4.5 mm screws that sit inside the battery slot.
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  5. Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  6. Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  7. Remove the five 3.5 mm screws that sit at the bottom of the camera. Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the logic board.
  8. Using a spudger, detach the white-capped wire. Using a spudger, detach the orange-capped wire and set the front cover aside.
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
Заключение
richard guenther
Участник с: 19.04.2010
183 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 30-38, Garner Spring 2010 Member of Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,695
