Введение
Replacing the front cover of a Nikon Coolpix 3500.
Выберете то, что вам нужно
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Remove the two 5 mm screws that sit near the camera strap eyelet.
Remove the camera strap eyelet.
Remove the five 3.5 mm screws that sit at the bottom of the camera.
Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
Using a spudger, detach the white-capped wire.
Using a spudger, detach the orange-capped wire and set the front cover aside.
