Nikon Coolpix 4600 LCD screen Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix 4600 LCD screen Replacement, Front and Rear Case: шаг 1, изображение 1 из 2 Nikon Coolpix 4600 LCD screen Replacement, Front and Rear Case: шаг 1, изображение 2 из 2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Nikon Coolpix 4600 LCD screen Replacement: шаг 2, изображение 1 из 2 Nikon Coolpix 4600 LCD screen Replacement: шаг 2, изображение 2 из 2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Nikon Coolpix 4600 LCD screen Replacement: шаг 3, изображение 1 из 1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
  4. Nikon Coolpix 4600 LCD screen Replacement, LCD screen: шаг 4, изображение 1 из 1
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
    • Be careful not to push the front case too hard on the table when taking the LCD out or the lens will get stuck.
    • Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
  5. Nikon Coolpix 4600 LCD screen Replacement: шаг 5, изображение 1 из 1
    • Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
    • Lift up on the black clamp and pull out data cable.
    • Desolder the wires from motherboard. CAUTION: Improper desoldering can result in motherboard damage. Seek help if you do not have the necessary skills.
    • The screen should now be completely free from the camera.
Заключение
3 участников успешно повторили данное руководство.
Nathan Sperling
Участник с: 05/08/12
119 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 9-43, Regan Spring 2012 Участник Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 1,235
