Nikon Coolpix 7900 LCD Screen Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix 7900 LCD Screen Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 LCD Screen Replacement: шаг 2, изображение 1 из 1
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 LCD Screen Replacement: шаг 3, изображение 1 из 1
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 LCD Screen Replacement: шаг 4, изображение 1 из 1
    • Carefully open the back cover. Take care as there are connectors still attached.
  5. Nikon Coolpix 7900 LCD Screen Replacement: шаг 5, изображение 1 из 1
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 LCD Screen Replacement: шаг 6, изображение 1 из 1
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
  7. Nikon Coolpix 7900 LCD Screen Replacement, LCD Screen: шаг 7, изображение 1 из 1
    • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
    • Carefully flip the screen down to reveal the back of the screen
  8. Nikon Coolpix 7900 LCD Screen Replacement: шаг 8, изображение 1 из 1
    • Disconnect the ribbon cable and gray connector with red and black wires.
    • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
Заключение
Kaky Payne
Участник с: 04/17/12
112 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 12-38, Regan Spring 2012 Участник Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 1,523
