Nikon Coolpix 995 LCD Replacement
Выберете то, что вам нужно
  1. Nikon Coolpix 995 LCD Replacement, LCD: шаг 1, изображение 1 из 2 Nikon Coolpix 995 LCD Replacement, LCD: шаг 1, изображение 2 из 2
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: шаг 2, изображение 1 из 1
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: шаг 3, изображение 1 из 1
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: шаг 4, изображение 1 из 2 Nikon Coolpix 995 LCD Replacement: шаг 4, изображение 2 из 2
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: шаг 5, изображение 1 из 1
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: шаг 6, изображение 1 из 1
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
Заключение
Cory Layman
Участник с: 10/04/11
93 Репутация
Автор 3 руководств
Команда
UW Stout, Team 1-5, Zhou Fall 2011 Участник UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 членов
Автор 7 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 33
За всё время: 2,902
