Введение
Safely replacing the battery door is a necessary step in protecting the internal components of the camera. Thoroughly completing this process also protects the waterproof integrity of the piece.
Выберете то, что вам нужно
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
After pressing the yellow tab, the battery should loosen.
Slowly pull the battery completely out.
Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
Using the metal spudger, carefully pry on the plastic plate.
The plastic plate should begin to loosen. Completely remove it from the camera body.
Open the battery door. Near the hinge, a pair of screws should now be exposed.
Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
Еще один человек закончил это руководство.
6 Комментариев
Where can I purchase the battery cover?
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Need web site to order battery door?
