Введение
The motherboard is the key component to making the camera run. If there is a faulty connection, the camera will not turn on at all. This repair should be completed with care, as to not interrupt the flow of power.
Выберете то, что вам нужно
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
After pressing the yellow tab, the battery should loosen.
Slowly pull the battery completely out.
Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
Carefully pull the plate off of the face.
Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
Remove the upper cover (connected by glue) and unscrew the single Philips screw.
Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
Using a Phillips #000 screwdriver, remove all 8, 4mm screws on the motherboard.
3 участников успешно повторили данное руководство.
Один комментарий
Thanks for this guide.
I managed to open 2 of theses and swap the sensor-unit from one to another.
Unluckily the camera remains broken since one only shows a black picture - even though the sensor is alright an the other has a broken AF from a fall, I suppose...
I am certain with some silicone grease on the orange rubber the camera would still be waterproof.
