Введение
This guide shows how to replace the assembly of the shutter button/mode selector dial/buttons. This assembly can be replaced if any of the buttons malfunction or are faulty. The back cove and bracket need to be removed before removing the button assembly.
Выберете то, что вам нужно
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
Open the HDMI flap to remove a 5.5mm screw.
Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
While twisting, pry apart the shell to split the camera in half.
Place the pry tool under the black latch. Lift gently until the latch flips up.
Gently pull the ribbon away from the latch.
Lift the corner under the power button up.
While at the same time pushing the selector knob back.
3 участников успешно повторили данное руководство.
