Введение
This guide shows how to replace the motherboard and battery housing. This can be replaced if there are any issues with the battery connectivity or the board blows out.
Выберете то, что вам нужно
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
Open the HDMI flap to remove a 5.5mm screw.
Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
While twisting, pry apart the shell to split the camera in half.
Place the pry tool under the black latch. Lift gently until the latch flips up.
Gently pull the ribbon away from the latch.
Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
Remove the single 6mm screw.
With the spudger tool gently pry off the white tap holding in the bracket.
Use the same tool to remove the glued-on ribbon.
With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
2 участников успешно повторили данное руководство.
